Use the following procedure to display the active Controllers and Gateways in the SPBM domain.
- Select SPB-PIM-GW.
- Select the Node tab.
Node Field Descriptions
Use the data in the following table to use the Node tab.
| Name | Description |
| MacAddress | Shows the MAC address of the active node. |
| HostName | Shows the host name of the active node. |
| RoleType | Shows the role of the active node: either gateway, controller, or both. |
